T
Tinster
The rear end of my 69TR bottoms out easily including most small speed bumps, regardless of speed it seems.
I have replaced the shocks, trailing arm bushings and diff mounts. Still bottomed out fairly easily and tail end still "crunches" when I push down on it.
Before the TR died on me, I had ordered new coil springs all around because by elimination, there was nothing else left that could give out under bumps vectors.
There is a difference of .75" between LR and RR at body and ground measured on flat surface on center line axels. 1.125" between front and rear- rear is lower.
The new coils arrived this week and using Bentley I now have the rear left suspension dismantled with the shock and axle waving in the breeze- the old coil out.
I noticed the four coils are of different heights. Two tall coils and two slightly shorter coils. The 8 plastic mounting rings are of two thicknesses also.
So please help me once again??
Which coils go in the rear and which mounting rings go with them? Or are the plastic mounting rings put on with one thin one and one fat one?? If so, top or bottom matter much?
BTW. The left rear coil spring on my TR had no mounting plastic on top- once I had it apart. Coil directly to frame steel. Maybe THAT was the nagging "crunch" sound I could not locate or get rid of??
tinster /ubbthreads/images/graemlins/patriot.gif /ubbthreads/images/graemlins/patriot.gif
