Happy Halloween to everyone!
I am rebuilding my rear brakes, and have two questions:
1. Installation of the spring plates is fiddly, at best! (Great discussion here, FYI: https://www.britishcarforum.com/bcf...p-Installation&highlight=wheel+cylinder+clips.) On my car, quite a bit of force was required (mallet and drift) to install the plates - and the result is the brake cylinder does not move "easily". I can move it by tapping with a rubber mallet, but can't move it without force. Is this too tight? If so, how can this be adjusted - all the parts are what they are... I could file a little on the cylinder itself?
2. The drum has a vent hole. Which way should this be oriented? I installed the drums such that the vent hole is directly over the adjuster. Is this correct?
Thanks!
Thanks!
