I was out looking at the rear axle today and I'm anxious that the hub is not tight on the gasket. there seems to be too large a space. (maybe 1/16") This causes me to wonder whether the bearing is properly seated. (There is no oil in currently as it's out of the car - so nothing leaks - yet)
I don't mind buying new gaskets & re-soing it but, before I do, any tricks to seating the bearing? Here's what happened.
I installed the bearing with a large socket, seemed tight - then, as I slid the bearing hub (#32) on the axle, the bearing slid out some - I pounded it flush (I thought) with the socket & some wood. The nut is torqued on but, then when I attached the half shaft, a gap remained
am I missing something? (BTW - not wire rims if that is relevant)
https://mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29295
Hi Guest!
