aeronca65t
Some time back, JollyRoger wrote about cold re-arcing the rear leaf springs (to lower a car in the rear).
He recommended using a sledge hammer and an anvil.
I had cold re-arced mine using a modified pipe bender, but it was a pain in the neck to get the springs really "even" and I had wanted to try his "hammer and anvil" method. I think Rob Selina had some success with it.
Last weekend at the Pittsburgh Vintage, I snapped three axles over two days, so obviously something was wrong with the axle housing.
In the end, I found out that my rear axle housing was bent like a pretzel and needed to be replaced.
I had apparently bent it in an "incident" at BeaveRun four weeks earlier, when I lost a wheel due to wheel-stud failure (Moss studs that I believe were inferior to the OEM studs). Before my left rear wheel went sailing away from me (at about 70 mph) it apparently "caught" and kinked the rear axle housing).
Anyway, since the rear had to come out, I pulled the leaf springs and tried my hand at re-doing the arc of the springs.
I have an anvil at work but not at home so I looked around for a "quasi-anvil" that I could use. Eventually I remembered that I had an old 1500 engine block (ruined from a con-rod escaping). After smoothing down any sharp edges, it made a perfect anvil.
I placed each leaf sping over an open bore hole and pounded away with my 4-lb. sledge, slowly moving along the length of each spring. After a bit of trial-and-error, it worked perfectly...much better than my pipe bender method. The springs are much more even and I can probably delete an axle spacer to boot. Great!
Also, I am trying a trick someone suggested regarding my oil seal leak (onto the rear brakes). Since I had a stripped down axle housing anyway, I pushed an oil seal in from the *inside* (through the pumpkin area). Since the diff was out anyway, it was easy to do this.
I'll see how it all works at Pocono (19 Aug)..
