Woodie
Ok I tried to repair a leaking rear axle seal, paper gasket and o ring. Took off the wheel, undid the 2 drum screws, pulled the drum, no third screw on the hub (HMMM), pulled the axel out and no paper gasket. (HMMM) Looked at the BIG nut to remove. No socket big enough. But all you guys kept saying "make sure you have the paper gasket or it will leak like a sive." Ok I replaced the paper gasket, oh yeah I also put the 3 screws in the right places and tightened every thing up. I will inspect in a few days to see if the cause of the leak was just the lack of the paper gasket.
SO my question, to change the o ring and seal I need to take off the big nut? Correct? and then what. Are they right there, do the ball bearings fall out? or is the bearing just open enough that you can see them. ?
