Webb Sledge
Re: Starter Problems
I took the starter off today and took some pictures for opinions. None of the wear on any of the gears looked excessive. Of course there is going to be some wear just from use, but nothing looked to be worn down to the point of failing to engage, as I checked the starter gear and around the entire ring gear. Here are a few pictures:
Ring gear looked like this all the way around:
https://img107.exs.cx/img107/5023/10000051yd.jpg
Someone mentioned that perhaps the battery was "over-engaging." I have an Interstate battery in the car, and I'm not sure if that would cause the problem or not.
Probably the most worn spot on the ring gear:
https://img107.exs.cx/img107/4458/10000094tj.jpg
The starter gear:
https://img107.exs.cx/img107/2087/10000080fb.jpg
The starter gear:
