Re: Oil Feed Kit for 1500
jim79
ok i read the post and ordered a oil feed kit for my 79 midget 1500. now my kit also had no instructions-no suprise. but my line has a banjo fitting on both ends of the line? where can i order the tee fitting so i can keep my oil pressure gage?
You should be able to tap into the oil gallery along the block without having to remove the pressure sender. There're a series of bolts along a boss in the block, parallel with the fitting for the pressure sender. Pick any one of them, if I'm not mistaken (Jeff would know for sure).
