Re: Fancy green silicone radiator hoses
2wrench
So do you use standard hose clamps on these
fancy green silicone radiator hoses or what's the
story, here?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Which I believe would be those nasty wire things[/QUOTE]
Randall, I believe that you just answered your own question.....
How about those new Gates heat on clamps that Moss sells? They look really neat, but I'm not sure that I'm ready to trust them.
Yeah ... but I wouldn't pay extra for green hoses, either. If I'm going out of my way to make it "original", then might as well do it right. If not, then I go for the most effective solution.
But I'm weird that way, so of course everyone should make their own decision.
The green silicone hoses aren't quite the same green as original. I have then on my car and you can use either the original wire type or any other hose clamp you might want.
Well.
I have the green hoses. They are from TRF. I can't believe they are silicon. I have blue silicon hoses on my Mustang GT. They are not at all alike.
Where do silicon hoses for TR6 originate?
FWIW I wouldn't use anything but the "Aero" style clamps.
Keep on.
Tosh,
You and I have green hoses from TRF, but they are not silicone.
The only silicone TR6 hoses available that I know of is a recent addition at Moss and they are very different than what we have. And you can only get an upper and lower rad hose, not the heater hoses.
And one of them is $45.00.
New Gates heat shrink clamps are below it.
How'd you get em off.(Doc speak)
Mine are still a bit different than that, lighter green and no pattern. Came from Cambrige Motorsport in the UK. Purchased in 2001.
Doc,
You cut um' off after heatin' um' on.
Paul,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]You and I have green hoses from TRF, but they are not silicone. [/QUOTE]
Understood.
Whoa! Them is buff.
Would it not be somewhat depressing if during removal of the Gates heat shrink clamp one were to slice inadvertently through the hose? Must be a special cutter for that sort of thing.
OTOH a <u>complete</u> set of those pieces sure would trim a showpiece engine compartment.
Keep on.
