tony barnhill said:
So, Hap, if I send you an MGB pan, can you do the same to it?
David answered the other tow questions quite well. Mvoing oil to the fornt of the pan probably not as big a deal in street car, but try to hit the track without some baffling and you may find your bearing and crank life to be rather short. Ray's car is street racer if you will and under regular street drivng is not a big issue, but we'll probably get ray out for a track day with this car, and he saw the pans on our race cars and wanted one for thios car, so he got one, Rays cars will have alot of features on it that most of race car have.
Tony I often wonder why someoen hasn't designed a square bottom pan for a MGB. I didn't make this pan, it custom made for Winners Circle, they sell it, they even make one above this pan called a super comp pan that has different pick up that sits at the very back of the pan, and it has both lateral and front to rear baffles and trap door, and the baffle is removeable. To design a pan like this would be a big job, real big job, it would have to take in effect the headers used, have to have chassis to jig up for it, lets just say I wouldn't touch it with a 10 foot pole and to make a prototype would be verrrrrrrrrrrrry expensive. Basil Adams and Headley both make baffled oil pans for MGBs, there no where near as trick as these WC Spridget pans, but the B racers swear by them. Spridget are one of the highest corner G force racers out there, and they probably need more than a B anyway. A good SCCA spridget race car can flirt with 2 Gs in a corner, you got to get a formula car to get that kind of Gs, why you think I wedge my big butt
in a Spridget race car when I could be racing a B, becunce nothing corners like a well set up Spridget, maybe a Super 7 or a real well prepped Spitfire.
Oh I just got this pan bolted on, I bet I have bolted down this type of WC pan on A-series blocks a 100 times, and there's still one bolt that will make you pull your hair out, it took me 30 minutes alone to get that one bolt tight, David you know the one
