Use a couple of cans of auto primer (black if you can find it) then sand with 1000 grit wet/dry paper. Then the gloss will go down MUCH better. The trick with the gloss is to put on a thinner gloss coat and let it get tacky (10 minutes) then come back with a good medium, wet on wet, coat. It will give you the best result possible for a cheap son of a gun like you. I know this because I'm a cheap son of a gun myself. Good Luck!
/ubbthreads/images/graemlins/thumbsup.gif
/ubbthreads/images/graemlins/iagree.gif Black primer is like gold around here, usually sold out everywhere....so I keep a stash; Duplicolor Black Sandable Primer is good stuff if you can find it.
[ QUOTE ]
[/ QUOTE ]
And don't skimp on the tack cloths after wet sanding.
Re: Rattle canning the top of my Eagle Talon [agai
and don't mix the cans of beer up with the cans of paint. That can ruin a really good day of painting, no matter which way the mistake goes... /ubbthreads/images/graemlins/smirk.gif
You dont need paint you need stickers lots of them. I bet if you did it right you could gain a min of 50hp and as a bonus be the envey of every 15/16 year old on the block.
