T
Tinster
I had to remove my twin carb heat shield plate in order
to install the new Ratco cable throttle linkage. The Ratco
mounting bracket will NOT fit with a carb heat shield
in place.
You folks with Ratcos-- What did you install to keep
your carb float bowls cool from the exhaust manifold heat?
Thanks as always,
d
in place.
Thanks as always,
d
