mightymidget
Installing rear end back into the Bugeye, I had ordered 4 of the "distance piece" as shown in catalog to install the radious rods. Once I got to installing I found two original distance pieces still stuck to rear end. During installation I could not install but one per side. I didn't have enough room to install one at body end of Radious only one per side in orginal location where they were stuck.
What is the correct amount needed. I have 4 brand new distance pieces that I didn't use left, but used the original two on the rear end side of mounting block on the axle
Hi Guest!
