G
Hey guys,
Tomorrow I am going to play around with my BMC radio. I have a few questions though.
- There is a positive/negative switch on the radio. This is a small round disc that I can pull out with 4 pins in it. I can put it back with the gap to "negative" (for my negative ground car). Is this indeed the way to do it or should it rotate? I seem to be only able to rotate the upper of the two discs and this does not seem to be of any electrical influence. The bottom disc does not seem to move.
- There are 4 wires. 1 green wire connected to the outer metal part. Is suppose this is ground? Then there is 1 black cable comming out of the internal part. And one cable consisting of two wires (stuck to eachother) comming out of the same internal hole.
Can anyone help me out here? /ubbthreads/images/graemlins/smile.gif Thnx!
