Today I topped off my hydraulic shocks, balanced the wire wheels, freed up the frozen passenger window regulator, added an audible "beeper" to the turn signal flasher, replaced the fuel pump, replaced the windscreen washer pump, and removed the (dead) 1990's vintage radio. Also had two cold Sam Adams.
To install my "new" BMC radio, I traced and freed up the appropriate wires and antenna lead, and found that the BMC radio slides right through the console radio hole. There's no mount, faceplate or bezel, or obvious way to fasten the unit into the console.
The 1990s radio was held in by a bezel on the console outside, and "tongues" inside, on the radio chassis, which bent up behind the console wall, locking the chassis in place. Press those bent tongues back flat to the chassis, and the whole radio slides forward out of the console. It's a "DIN" mount. Bend the tongues upward from the chassis and it's locked into place.
Evidently the BMC radio needs to be mounted using shaft nuts, but of course there are no holes for the shafts to fit through.
Has anyone installed a (older) radio in a MGB? Mine is a 75/76 model, which has most of the dash features of early-70s roadsters.
Is there some sort of mounting kit available? My local radio guy says there is nothing made to go from DIN to shaft mount; he says someone must have cut out the original console holes to make a single rectangular DIN hole.
Thanks.
Tom
Thanks.
Tom
