This is a TD question. My TD did not have a thermostat and there was an valve that was inline that is not supposed to be there. If you are unfamiliar with a TD here goes.
There is a large cast elbow coming off the block and then another housing bolted to it. This housing is for the thermostat and connects to the top of the radiator. Out of the side of this housing is an opening for a much smaller cast elbow. This elbow connects to a "Y". This "Y" connects the water pump & the lower radiator hose.
The PO brazed an angle valve into the small elbow to somehow restrict flow. Why?
Particulars:
Car was from Socal
No thermostat.
Added a flow valve
Radiator cap was a flip type & not the std. screw down Octogon.
This pic is of the small cast elbow on top of the "Y". There is also a fiting brazed into the "Y which needs to come out.
I need to figure out which thermostat to buy & why he might have had a setup like this.
Particulars:
Car was from Socal
No thermostat.
Added a flow valve
