RJS
Happy Memorial Day! I hope everyone is having a great weekend.
I must say I am so disappointed. After all that time straightening radiator fins (5 hours with a mini screw driver straighten each bent fin), re-soldering the side frame to the bottom, repainting (the rad and fan look like works of art)...I put it all back together yesterday only to discover I have 2, maybe 3, new pin hole leaks in the radiator now.
This is the original rad which appears to have had some soldering repairs in the past.
-I am very reluctant to use any "magic" radiator stop leak
-I doubt this is something I can repair myself with a soldering iron (correct me if I a wrong)
I did locate a radiator shop on the web in the next town which advertises they work on vintage, hot rod and custom radiators.
I can pull the whole radiator out in about 30 minutes now that I have done it. It just means more time off the road and expense (hopefully nominal though). I am hopeful they can repair it for less than $150. Is that realistic?
Thoughts? What are my options?
Thanks
Bob
PS: I fixed the fan mounting. After owning the car for ~9 years, I realized the previous owner had mounted the rad fan backwards. The pitch in the blades was still correct but, the curve in the blade was facing the wrong way. So, while the fan still pulled air, I am pretty sure it now pulls much more air than before!
Thanks
Bob
