if your cooling system is in good shape, you shouldn't need more than 4 lbs. more pressure risks bursting things. if you overheat, find the cause and fix it. make sure the cap is long enough to seal, or it wont make any diff how much pressure it has. i needed a cap for a truck to seal.
