Deleted member 12521
Just started up the '57 TR3A engine yesterday after it had been sitting for almost 32 years. Points set, good spark, it started up easily using the push button on the dash, and it idled nicely; we gravity-fed fuel to the carbs from a bottle (didn't want to bother with what may be in the tank or if the fuel pump works, yet). Gauges indicated it was charging and the oil pressure was about 20 when idling and up to 50 when revving up to 4000 rpm.
This was without the rad installed, and we had a garden hose putting some water through.
Today we installed a rad and filled it, and the engine initially started up no problem, then died after running for a minute and we couldn't get it going again. The carbs need a rebuild and the plugs were pretty wet (with gas), but it seemed to be more than flooding.
As we had only changed one thing from yesterday, we took the rad off and it started up right away. We hadn't greased the water pump, but it wasn't making any noise and the belt is pretty loose anyway. I don't think it's the head gasket, maybe it's an electrical issue when the rad is installed? Maybe the engine is flooding with gas and the rad being installed was just coincidental?
Any ideas appreciated.
