I am replacing the two original radiator fans on my A/C TR8 with a single larger fan. The original driver's side fan is wired between the the hot purple and the two yellow grounds. When replacing that driver's side fan with the new fan connected between the same wires and disconnecting the passenger's side fan, the single fan receives no voltage. (The manifold temp switch has been disconnected by the PO and both original fans had been working off the rad temp switch). What am I missing?
