<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mailbox:
Dave,
Let me be sure I understand what you are saying. Moving the rack foward or back from it's current location might be OK, but do not move it up or down from it's current location. Did I read it right?
<hr></blockquote>
Yes, you read it right.
Bump steer is actually toe in or out changes with vertical wheel travel. Visualize the suspension being at mid travel & the rack in perfect vertical alignment with the steering arms. (Tie rods parallel to the ground). As the wheel travels up or down, the effective tie rod length gets shorter & causes the wheels to toe in or out from where it would be at the mid travel position. Toe in if the rack is in front of the wheel centers.
Most steering systems are a compromise to minimize the toe changes with wheel travel, but there is still a slight amount. Of course uneven suspension positions such as cornering, will cause one side to change toe more than the other & steering may be erratic. Heavy anti sway bars help minimize this change by keeping both sides more nearly the same.
Since the suspension only allows the wheels to travel vertically, moving the rack fore & aft does not affect this toe change (effective tie rod length) very much, as long as the rod lengths are changed to keep the desired static toe setting. Quite a few cars have the rack fore or aft of the steering arm connection centerlines & work well.
If you have radically changed the suspension height you might need to move the rack up or down to match.
If anyone disagrees with this, I could be wrong, so please jump in.
[ 03-27-2004: Message edited by: Dave Russell ]</p>
