ChrisS
I need some practical advice from the race folks. I’m gearing up to build my first race engine and would like to run my setup by you to see what I’m wasting money on and what I’m missing. This will be for time trials and autocross this year, preparing for wheel to wheel next year.
1275 block, 0.060” overbore (max rules limit)
Polished and balanced crank (is it worth wedging?)
Stock rods
ARP rod bolts
AE 21253 8cc dish pistons
Stock 9 bolt head, (I need a recommendation on valve sizes, I was thinking of using SS Cooper S race valves, 1.401” intake, 1.22” exhaust, is it worth going with rimflow valves?)
Upgraded valve springs
Stock cam (race rules, I have a spare Isky MM55 cam as well which is 268’ duration for autocross)
Stock lifters, push rods and rockers
Stock timing chain / gears with offset keys as needed
ARP studs for the head (is it necessary to add holes / tap block for 11 studs?)
Stock intake manifold
Smoothed SU’s through intake to head (major porting not allowed)
LCB header
Crane HI-6 CD Ignition box (it will fire from a Pertronix trigger most likely)
Lightened flywheel (exaggerate the step between the friction surface and the ring gear)
So does this sound like a safe starting point? What have others done?
Thanks
Stock rods
ARP rod bolts
LCB header
Thanks
