RJS
Hi All,
So, some of you have probably seen my recent post on axle shafts. My reason for posting was due to rear end clunks when pulling away from a stop in 1st gear. I had the differential rebuilt 4,500 miles ago (as well as confirming condition of diff mount pins and renewing all the diff bushings). That being the case, I suspected u-joints or splined axle shafts (dismissing the idea it could be the diff). I pulled the hubs and axle shafts this weekend. Granted there is a minor bit of play in the u-joints and splined axle shafts but, hardly enough to give the loud clunk I am experiencing.
So, I am wondering if it could be the differential again? I was considering CV joint axle shafts but now I am wondering if my money would be better spent on a Nissan R200 diff upgrade. Questions:
I did play with the differential a bit but, not sure I was testing it correctly. If I grab the two output flanges and rotate, there was barely 1 degree of rotational play. But, on the input flange, there was probably 3-4 degrees of play (which seems excessive to me) and a fairly audible clunk when it met its stop.
Thanks
Bob
- How can I test my current differential for excessive play or lash? It is mounted in the car with axle shafts disconnected but, drive shaft is still connected
- It is reasonable that my diff (rebuilt 4,500 miles ago) could be suffering excessive lash again so soon? (thus confirming it is a weak unit from the get-go and reinforces my decision to upgrade)
- For those of you who installed the R200 differential upgrade, would you say that that change alone solved your clunking issue?
Thanks
Bob
