Still getting the CLICK from the starter relay on the 74 OD TR6 with nothing else happening. Pulled the brand-new-looking gear reduction starter and tested the wires. I have 12V coming from the red/white relay all the way to the wire at the starter when the key is turned and 12V constant from the battery to the big post.
This is how it was wired: Red cable from battery on the big terminal. Red/white from relay on the small screw terminal on the opposite side of the starter. Nothing plugged into the little covered spade connector next to the big positive battery terminal. (Is ground supposed to be there?) Now I can't remember if there was a wire running from the front to the back, but I'll check when I run back up to my garage.
Am I missing something? It has been about seven years since I last wired a gear reduction starter -- and that was to a TR3 with an external solenoid.
Thanks for the help guys.
Hi Guest!
