MrPandy
The old dash is off my '71 TR6 and now the fun begins.
Temp, gas and oil gauges don't work. I tried grounding the wire at the temp sender - temp gauge swings completely to Hot! Ordering new temperature sending unit.
After further investigation, I determined that previous owner hooked up the trunk light switch wires to the fuel tank sending unit. I found the correct wires, touched the one to ground, and gauge reads Full! However, attaching them to the fuel sending unit does nothing. Cound the sender have gotten damaged by the power from the trunk light being hooked up? I guess it's "drop the tank and replace the sending unit" time. Add it to the order.
Oil pressure gauge - mystery! There's a clipped-off green wire on a screw terminal and an unused spade terminal - no oil tube connector. It's a Smith's gauge, but this isn't original, is it? Is there any way to make it work on my car?
Finally, I'm going to take off the rings and glass from the gauges to give them a good cleaning. I need the rubber rings that go between the glass and the gauges. Has anyone been able to just get these at a hardware store?
Thanks!
Thanks!
