Can I be reasonably comfortable that using a good auto paint from a can on the shelf will result in a good paint job--assuming I prep correctly?
I'm only painting my engine compartment. For my primer, I'm using an etch primer because I've got lots of bare metal. My question, though is this: Why not always use an etch primer? If it adheres better, isn't that always better?
Finally, some of the existing paint that I must paint over (it's right where the bad stuff is) is a really good hard acrylic. Do I just buff it up a little bit with 320 before priming that area, too? I assume the etch primer will help adhere to the existing acrylic without taking that down to bare steel, correct? Otherwise, I'm really in for a lot work over not much--the problem is mainly the typical corrosion on the battery box, hydraulic plate, etc.
Thanks all.
Thanks all.
