I note in "The Orginal Sprite and Midget" that the overflow fuel line for the front carb bends under the carb and runs toward the rear of the car. Right on the hot exhaust I guess.
Jack, I have HS2s, but I use the metal cross-over pipe with a T in it instead of two separate lines) with the T at the rear, routed over the bell housing and down the starter side with a length of rubber fuel line bringing it down past the clutch slave. I do not know if that is "correct" but it is safer! This is the same pipe that I suggested (in an earlier post) you cut down and use for the Y .
