jlaird
The orginal workshop manual says:
"Place the phosphor gronze thrust washer over the swivel axle. Put a shim on to the swivel pin, follwoed by the trunnion............"
However the pic shows the shim under the thrust washer. Now, mine are not apart but which is correct. I think mine are too tight but want to check for proper shime placement as well.
