The same heat range that works for a 948, works for a 1275, and a MGB for that matter. I'm a big fan of NGK plugs, been using them over 20 years. The "P" in the part number of the NGK plug stand for projected tip, this work good for a stockish type motor, as you start shaving heads, bumping up cmpression ratio with perfofmance motors, lose the "P", and go with a plug without the projected tips, for example we most commonly use B8ES, B9ES, and B10ES in the race engine, NGK, makes even fancier, more expensive plugs, but they have never shown us any increase in HP on the dyno, so save your money.
