Geo, here is a repeat of an article in the Triumph Roadster Review in 1977. Steering slack: Q? My 1947 Roadster is in good condition apart from the steering. How can I adjust the slack out of the system? A: Bearing in mind that there are a large number of components which would cause excessive 'backlash' if worn, your first task should be to check for worn track-rod ball-joints, king pins and bushes,worn front suspension shackle-pins and bushes, or wear in the steering box itself. The steering box is adjusted by first removing any end float on the sterring column (inner) by removing shims from under the end cover plate. Following this, with the road wheels facing straight ahead, remove the locknut and hexagon locking washer from the adjuster screw in the top cover plate. Turn the screw clockwise until movement of the rocker shaft is reduced to 1/64 inch, then refit washer and locknut. If this fails to help, I also found the complete reconditioning of the steering box article giving the specks on bushing and other assorted machining and majorly how to get it out. Haven't hear back from Akker site yet. Wayne
