Question, felt
jlaird
Anyone have an idea for the very thick felt squares that go under the spare tire on a Bugeye?
Also a source for a spare tie down strap, the three legged thing.
If you don't find the felt you want at the link above, don't forget that you can get felt from McMaster-Carr ( www.mcmaster.com ). From their opening page key in "felt" in the find products field and search for bulk material the thickness you need.
Thanks, they have quite a few good hard to find items. Thanks again.
Home depot has some fairly thick tan colored felt with adhesive backing in 3x6 sheets that is used for furniture lamps and such that may work.
Oh, just may. Will check that. I could even stack it if necessary.
