Question-door seals
jlaird
I have forgotten.
What or how are they fitted front and rear, anything?
How do you cover the ends? Anything?
How far up on the front, just up the door straight part or along the part to the dash?
Anyone have a pic of the ends? I can't find any.
Thanks
Unfortunately I cannot answer any of your questions, but I have been given the following advice for when I need to do mine:
Cut it long and squeeze it into place: If you don't it will shrink over time and leave gaps at both ends.
When you put the glue on the seal don't worry about it getting on the carpet: a little light machine oil on a rag will lift it off quite easily.
I have also been told to buy 2 lots of seals so that it can be put on during mock-up before painting, but as you are a little beyoind this point it doesn't really matter!
No glue for mine, Moss red that matches interior, actually I think made by MacGuire.
No pics, anyone??
Jack
On the Bugeye the seals get tucked up under the corner of the dash and again tucked behind the dog leg interior panel sort of right near the top bow bracket.
If your seals have aluminum clips, just glue them on now to save aggravation next week when they fall off.
Mine were aluminum from AH Spares, they don't work.
Got the rear, found the screw hole. Now I need a clip for the front? I don't remember that.
Got it, run the rear seal back and down under the panel behind the top bow fitting.
Use a u shaped hose fastner on the front and attach it to the first bolt on the front cockpit suround. Works a charm.
No hose fastener here...
Hose fastner works great, hides all.
Pleased with it.
