jlaird
The good books say check float level 1/8 inch drill bit between the body and under the lever thing. OK mine are much more than that. However it seems to me that a larger opening would depress the float and allow less fuel in the chamber, ie close the valve sooner thus preventing over flow. Agree??
Now the fuel in the chamber exits the bottom and goes to the bottom of the needle and choke assy. That is where my leak is, I have checked my assy and seems I have put them together correctly. Heck overnite the float chambers have run dry. Ideas??????????????????? Yep I know where the leak is, how in the world do I fix it. What have I done wrong?
I do not suspect the fuel pressure as I do not get overfill of the fuel float chambers as no fuel is pushed out the drain tubes.
