jlaird
Right now the carb throtle arm faces toward the outside. As I look at the cable etc it seems it should be on the inside faceing toward the heat sheld.
Now the only way I can see to make that work is to change the throtle plates so they open the other direction. Think the person who put new throtle shafts in got it
backwards?????????
Forgot to say that the top of the throtle plates point toward the engine, is this correct? To make it turn the other way they will point out.
What you all say, the throtle arm is a small brass peice.
backwards?????????
