Hi Rob,
It's not possible to accurately convert CR to PSI. Nial is correct. To carry
it a bit further, the following explanation may help.
Question: “If an engine has compression readings around 165 PSI, and
that is taken at face value; that means the compression ratio is
165/14.7 ~ 11.2:1. This is much higher than the published numbers.
That air must get really warm when you ‘squish’ it.”
Answer: That calculation is correct for "isothermal" compression which
assumes that no heat is gained or lost during the compression cycle, and
if the actual compression ratio is the same as the rated ratio.
To complicate the calculation, at low RPM, such as at cranking speeds, the
actual engine compression ratio is never the design calculated ratio
because in reality the piston cannot begin to compress anything until
the intake valve gets closed. If the intake valve were to be completely
closed at BDC -- which by design it never is -- the actual and rated
compression ratios would be the same. At higher RPMs and thus higher
intake gas velocities, the late closing of the intake valve is offset by the
gas inertia in the intake tract and the engine can approach or exceed its
design compression ratio.
The formula for "adiabatic" compression takes heat loss or gain
into consideration. For example, as the air is compressed it is heated
by the compression and the final pressure is higher than would be
predicted by isothermal compression. The variables are rather large and
the difference between the two calculations can vary by a factor of
almost two to one in the final pressure. The pressure rise due to
heating is an "exponential" function (i.e., more heat = more pressure =
more heat = more pressure). The "exponent" for air will vary from one
with complete heat loss to about 1.4 with no heat loss.
For a hypothetical engine with 9:1 compression ratio, assume that the
actual mechanical compression ratio is 6:1 due to late intake valve
closing. We can calculate that the pressure for isothermal compression
would be 14.7 x 6 = 88 PSI. With an adiabatic exponent of 1.14 this
would give a compression pressure of 165 PSI. (88 raised to the 1.14 power)
Whether heat is gained or lost during compression depends on several
things such as how quickly the compression takes place (starter and
engine cranking speed), temperature of the engine during the test (is
the air in the cylinder hotter or cooler than the air compressed in
it?), and a few other variables. The end result is usually that the
measured compression pressure is higher than would be calculated by
The compression pressures given at "face value" are empirically
determined from measurements and experience. There are just too many
variables to make accurate calculations.
