Hello all. I had rebuilt my slave cylinder and put a hydraulic line on today yet I have a problem. This all started when I went out to my car last week and the master was empty with fluid on the floor. The master didnt show any signs of leaking so I only rebuilt the slave. When I rebuilt the slave I only changed the rubber nose piece. The rubber piston ring I got when I put it on wouldnt allow the piston to work and would just bind in the inside and the spring wouldnt push it back. The old piston ring seemed ok so I put that back on and the piston would then work again. I put the cylinder back on and bled it pretty good to the point when I open the bleeder I get a nice shot of fluid out of it. I got in the car and pushed in the pedal with my foot and it is very limp. For sure it is not good enough to drive and shift properly. I can get it in first but thats it. I dont think there is anything wrong with the clutch as the day I parked it I had no trouble. Im pretty sure my problem is the hydraulic system. The rod from the slave when the cylinder was off I could push in and out easily and was limp. Should that rod be easy to move back and forth by hand with the slave off? Im starting to wonder if my throwout bearing gave out then causing the slave rod to come out and the fluid was able to run through?
Any thoughts on this? Im really concerned with this as I hope its not the clutch.
