GregW
So I had to build a computer quickly for work recently. Simple small one, thought it would be easy. XP refused to load with a BSOD stating PCI.sys was the culprit. Same result with another XP disk. I had a copy of Vista laying around (gasp), so I tried that. Got the OS up but for the life of me, I can't get the dual monitors to work. Replaced the motherboard, same. Tried a different power lead to the video card and was able to clone the desktop onto the second monitor. Ah! progress, must be a bad power supply. Got a 500w supply, no joy. Well, Windows 7 came out yesterday, so I downloaded the 64 bit version. Exact same problem. I can have one monitor, or the other work fine. I can have both monitors working fine when cloned. When I switch to an extended desktop, the primary monitor becomes unreadable with diagonal lines, the secondary monitor works fine. I can switch which monitor is the primary, but the diagonal lines follow it to that monitor. Any ideas out there?
