Push Starting a F-100 Jet
Steve_S
Sent to me by a friend...
Marine Ground Crew Finds F-100 'SuperSabre' Had An Unbelievable Starting Option
The F-100 SuperSabre had a large chamber to accept a large gas-generating cartridge. When ignited by electrical current, the expanding gas from the black powder-like pyrotechnic cartridge drove a starter turbine which brought the engine up to a self-sustaining RPM via a drive system.
This eliminated the need for heavy and bulky ground starting units, but the starter cartridge spewed out a characteristic dense cloud of choking black smoke, which was often mistaken by inexperienced ground crews for an engine fire.
The powder charge for the ground start came in a big sealed can, and upon opening and extracting the cartridge, you'd find two small metal tabs on the bottom of the cartridge. These tabs were the electrical contact that fired the cartridge when the pilot moved the throttle outboard on start, before bringing the throttle forward. As soon as a tiny RPM registered on the tach, you brought the throttle around the horn to feed fuel and engine ignition to the rapidly-building engine speed.
Sometimes the big metal receptacle that held the gas generator cartridge would get so dirty from repeated use that the metal tabs wouldn't make contact. Then the cartridge would refuse to fire, and the crewchief would give the starter receptacle a good healthy whack with a wooden wheel chock, usually curing the powder charge of any reluctance to detonate.
We'd often take a can containing a starter cartridge along with us as an alternative starting means on cross-country.
So, let the journey begin ~~~~~
Then- USAF Captain John Green flew his F-100 one day into the Marine Corps Air Station (aka NAS Millington) outside of Memphis one day, back in the early '70s, for fuel.
He was met by a couple of young Marine ground crewmen, who asked what kind of plane he was flying. F-100 'Supersabre' only got him further puzzled looks. One of the ground crew said, " Sir, I don't think we have tech data on this bird. What do you need for start . . a huffer . . or just electrical"?
"Neither one," John replied with his tongue in his cheek. "If I can get, oh, about six of you guys to give me a push to start me rolling, I'll just 'pop the clutch' and get the engine started that way."
More and more doubtful looks, but, "Uhhh,Yessir," was the final comeback. What else would a young Marine say ?
The 'Hun' was pretty finely balanced aircraft on the two main gear struts, so when you tapped the toe brakes, the nose strut compressed so much that the nose would dip, just like the hood of cars used to dip when being clutch-started after a similar push from young friends.
So, now six Marines are standing at the ready, still doubtful, but not about to question an officer on 'procedure.'" Just get me going at about a fast walk," John called down from the cockpit. " I'll wave you all clear when we're fast enough, pop the clutch on this baby, and be on my way. And thanks for the good turnaround! "
With six Marines pushing, they quickly get the bird up to a brisk-stepping speed. John waves his arms, and the Marines warily stand well clear.
The nose dips as John "pops the clutch." There is a huge cloud of choking black smoke as the starter cartridge goes off, the Hun's engine whines into life, and off goes Captain Green to the end of the runway, leaving six puzzled Marines in his wake.
Steve, Greens' story is an oldie, but a goodie.
It was standard procedure to carry a couple of cartridges on a X country, as sometimes conventional ground start capabilities may not be available. If you had never done a cartridge start before, it was SOP to practice a couple before departure, as the starting sequence was somewhat different using the shotgun starter.
I remember one of our F-100's being mobbed by a bunch of young troops with fire bottles, as they thought it was on fire!
For those that don't remember the old girl, here's an F-100C over Tuy Hoa, RVN.
Jeff
Heeheeeheeee!!!!
I'd lost that in th' wreckage of grey matter loosely referred to as my "brain". It gave me a laugh when I first heard it and an even more gratifying one now... The report from the cannister was kinda distinct too, IIRC.
... I found some of my 'chromes today, Jeff. Scanning some in: Glen F-1 shots first. Some F-4 stuff next.
Bugeye58 said:
... over Tuy Hoa, RVN.
Jeff
that wouldn't happen to be pronounced "tooee waa" would it? Cause I seem to recall a phrase with that phonetic sound meaning "very stinkie" or something along those lines anyways.
Rob, "tooee waa" it is, indeed. Although, it was a rather pleasant place compared to other parts of the country. Only an <u>occasional</u> rocket attack to mar the serenity.
Jeff
