My speedometer (TR3A w/OD) pulses. It waves in a 5 to 10 mph range roughly centered around the correct speed.
I have had it apart, cleaned the old hard grease and reassembled it (there goes my "calibration").
I swapped it with the tachometer, and it shows engine rpm nice and steady. The tachometer attached to the speedometer cable is nice and steady.
I have a new speedo cable from VB, and I think it may be the problem. The pulsing coincides exactly with the small movements of the odometers when the ratchet moves them.
I think the new long speedo cable is flexible enough to wind up a bit with the ratcheting, and then release. I don't remember this happening with the old cable. I don't the old one anymore to compare.
Does that sound logical? Anyone else seen this happen? Are there "bad" speedo cables out there?
