ronzet
As my late father always said..
'If there isn't time to do it right... there will always be time to do it over...'
Quickly -- When I had the tranny out during the restoration I had it rebuilt at a local shop. Second gear grinds upshifting and down unless I am very gentle or throw a great double-clutch.
I THOUGHT that this was normal until I had an opportunity to drive a friend's '57 Magnette last night. This car has the same drive train as the A. All the gears (2,3,4th) shift up and down without a wimper or groan...
SO... I will need to pull the tranny to <span style="font-weight: bold">RE</span>-re-build it... This project will be undertaken either now IF I <span style="text-decoration: underline">do not </span>need to dis-assemble the tunnel and all of the freshly installed carpeting and floorboards or LATER if I do...
This also opens up a world of 'Just as Wells'... You know, everything that I didn't do quite right the first time...
Any comments on the best course of action??
