Carlbanan56
Hi, for about 1 year now I have been working on my granddad's 1975 MGB that hasn't run since 1994. Yesterday I tuned the HIF4 carburetors and was finally able to take the car for a spin around the block. The car is not yet ready for daily use I still have to go through the breaks and a bunch of other stuff.
Although I tuned the carbs well enough to take the car around the block I think I may have run into a problem. When toning the carbs I think I have screwd the mixture screws all the way in and the car is still running lean. I think it is running lean because when I lift the piston the RPM instantly drops. To me, this sounds like the engine draws air not only through the carbs. Could this be true? If so how do I navigate to a fix?
Young and inexperienced, so every answer is greatly appreciated.
