PT Cruiser Fog Lights
Administrator
Boss
The battery died on my younger son's PT Cruiser, so yesterday I went to help him. First we took the battery to Autozone and tested it - dead as a doornail. We bought a new battery and the car started fine, but the fog lights would not turn off after shutting the car off. Thus, they would drain the battery in short order. After I little internet sleuthing, I discovered that this is a common problem on PT Cruisers. Seems to be a poor design in the multi-function switch (Turn signal/ lights) that causes a plastic part inside to over heat and, in time, melt to the point that it shorts out the fog light circuit. The good news is, the multi-function switch was available on EBAy for only $50. I also found a great video explaining in detail how to change the MF switch (it's not hard, but there are a few little tricks that you need to know that are not obvious).
Thank you for that tip.
You Tube is a great tool and a terrible time suck.
I find I look at something on you tube then another video catches my eye then another and before I know it the morning/evening is gone.
Have learned how to do so many things on you tube.
David
David
I know what you mean! I spent the better part of an evening recently watching ABBA videos! LOL
I've done several. NEW at autozone, o'reillys, etc they are 50-60 WITH a lifetime warranty you won't get on evilbait.
Wasn't there a way to insert a relay in the circuit to take the pressure off the switch? PJ
