jlaird
On off switch installed, used a house wall switch. One side hot the other to fuel pump and coil.
Water in radiator, hay don't forget to close the block drain valve. hehe
All in readyness I think to bring Miss Agatha to life. All that needs done is throw the switch and crank her. However, I am going to do a bit of dry cranking first to try to get some oil pressure.
Only thing I don't like at this point is that the chokes are so tight, but I expect they will loosen up with a bit of use.
/ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/thirsty.gif /ubbthreads/images/graemlins/patriot.gif
