There is light at the end of the driveway. Since I got the car in February, I've made some progress:
- replaced the starter
- repaired the oil pressure gauge
- greased every zerk fitting in the universe
- correctly wired the turn signals, brake lights, panel lights, high beam indicator, heater switch
- cleaned up and added missing belts to spare compartment
- rebuilt, reset, rebalanced carbs
- restored choke/jets to proper function
- added the missing door draft seals
- fitted new hoodstick cover
- added heat insulation under all carpeting
- made new needle for fuel gauge
- cleaned all gauges, panel lights, switches
- refinished panel with black wrinkle paint
- added 90wt oil to (dry) steering column
- repaired rusted out areas on both floorpans
- polished rocker cover and dashpots
- cleaned wiper motor/gearbox and restored autopark
- replaced prop shaft u-joints
- repaired and refitted windscreen wipers
- replaced broken bonnet cover hinges
- replaced all throttle linkage (except butterfly shaft)
- repaired rusted battery box
- changed oil and filter cartridge
- flushed heater core
- driven 250+ miles
The above list is probably nothing big for you all, but for me - the personification of "klutz" - it's a major accomplishment.
And absolutely NONE of this would have been possible without your help. THANK YOU ALL!
With greatest appreciation, respect and admiration -
Tom
- driven 250+ miles
Tom
