Progress - Question again
jlaird
Fuel system is in, tank, pump, and pluming.
Organized the Hyd lines as they hook to blanking plate bolts. Installed, coil bracket.
Question: The fuel line from the tank comes from the rear on the passanger side with the Hyd line hooked with those small clips. Now where does it cross over to to the carb side at which end of the engine room. Under the rear or the front? Is there something there that holds it tight?
The fuel line crosses at the trsnny frame rail then runs up the left rail where it is clipped to the left motormount bolt.
There were a couple of frame/pipe clips along the rails.
Thanks Frank, now that you said it I kind of remember, no problem, will make it happen. Think I even have those clips some place.
