GB1
Finally got the cam in and the timing set 1.5 degree's off and it is forwarded/advanced. It took some time, but is finally done.
IMHO, it is the most time consuming part of the an engine rebuild.
Doc, I McGyvered the crank shim with a fender washer and an arbor bit, alot of sanding and dremel.
Patrick
Patrick
