jlaird
Picked up all the engine from the machine shop.
Bore block .060 over and fit pistons $80
Clean & R+R plugs and bolts $50
Clean and polish crank Std rods and mains $27.50
R+R rods\pistons $24
Valve job $80
R+R guides $16
Resurface head $35
Resurface flywheel $35
Total 347.50
Also polished the cam bearings and removed two bolts with heat on a spring and reset two bolt holes for tapered bolts under the timeing chain.
I think I done good /ubbthreads/images/graemlins/grin.gif
Valve job $80
R+R guides $16
Resurface head $35
Total 347.50
