Well, the very good news is that I'm back at it. Actually, Tuesday, a friend is coming to pound some dents and then off to be stripped/ primed and possibly bottom finish coated, then somewhere else for bodywork/ paint - hurray!
While I'm waiting, I started taking the rear brakes apart (one side at a time - finally getting smart /bcforum/images/%%GRAEMLIN_URL%%/square.gif At the same time I'm replacing the rear bearings. Here are tonight's questions (there are a few)
1. The adjustment piece on the bottom, where the bottom of the brake shoes pivot - does that come off? If so, how?
2. In Bentley's Book (the 1500 one 75-79) on page 272, there is a diagram entitled, Half-Shaft, Bearing and Oil Seal. As I dismantled, there was no #7 gasket & O-ring seal - is this normal?
3. Do I need a hub puller to remove the bearing?
4. Does #10 (in the book) come off too?
TIA all I appreciate it
