Progress and a question
jlaird
Fuel tank in. Now where the hyd lines come down along the inside of the blanking plate are they attached someplace to the blanking plate and how do they clear the fan motor?
Pic????????
See those what I think are double clips?? Hard to tell from that shot for sure.
I vaguely remember there might be some clips. I'll be home in about an hour, will check then.
Thank you Drew. Fuel tank is in. That is a pain job with the new rubber gromitt. Took three hands. But surely looks good hanging under there, now on to the fuel lines, pump, and filter.
Mine is using the same type clamps that hold the lines to the firewall, One on each line attached to the blanking plate screws at the top. Kinda staggered from 2 separate screws.
There is a double clip at the top, and a single clip at the bottom. I've no reason to believe this isn't original, but certainly can't prove that.
Single clip is holding the clutch line as it makes the 90 degree bend.
I see that, good pic and thanks, that will sort it out I beleive. See how the lines just miss the indent that the heater moter reclines into, need that bit of space for sure.
Thanks again Drew.
Glad to help, Jack.
