First, let me apologize... to Jack, in case my posts and the subsequent responses hijack his original post on his progress. This was totally unintended and meant as a praise of your efforts. My second apology is to my car, as everyone will now see that I have been derelict in my duties...and I bow my head in shame. Third, I apologize to everyone else for the long post that follows:
OK.. First to Trevor. (sigh) I took the car off the road 1.5 years ago (March 2006). Not a dang thing really wrong with the LBC, other than it 'chunked' a little going into 2nd gear (probably due to PO, since it was that way when I bought it).
I planned on fixing that and just cleaning up the engine bay while the engine was out. Upon inspection, the tranny wasn't bad, but needed a little more work that just 2nd gear and a clean up. That is where the trouble started. I got a wild hair to upgrade to a Rivergate 5-spd to help the roadability. Found a good deal on the Datsun tranny out of Washington State. Had a local shop here clean it up and check it out. Ordered the Rivergate kit from the Perry's, then had work get in the way for a while. 2-3 months later got back, decided to take the engine apart (hey, it was already out and pleading me to!). Good thing. found grooves on the crank, did that.. had the head/valves/guide/etc checked and replaced guides/etc. Had the oil galleries done. Put new bearings/rings/etc as I went back together (probably other stuff done that I have forgotten I did). Then another stoppage due to a family thing. When I got back to it, decided I needed an aluminum flywheel, instead of the perfectly good original one. Had to have the aluminum flywheel milled, since the HW shoulder didn't clear the Rivergate engine backplate/seal bolts...which meant balancing too. Finally got engine/tranny put back together and had another stoppage... ok, it got HOT here. Finally got back to it in Jan 2007 to put everything back in. Engine in the bay, mounted and driveshaft connected. Then the wife decided she needed a kitchen remodel done. All that is left is to finish attaching the tranny tunnel mount and bolts, the new clutch slave, cooling system stuff, generator, peripheral back on...then put the pedal box back together and back in the car, and find the battery charger, before I can attempt to start it (ok, I probably forgot some steps here! I am not looking at the book).
One thing I also forgot to mention was, when I first started this, I also bought a powder coat gun and a small oven and went stupid with that too in the interim.
In reply to Morris: The car (and it's shameful owner) is located is Georgetown Texas... just north of Austin...
Hanging my head in shame, waiting for the flogging to begin...
Larry
