andrea
I am just returned from my holiday, and beginning to first test drives my AH following the 5-50-500 miles program
apparisched on Austin Healey Magazine page 29 September October 2011
All is good -
Start is OK Car start immediately at the first turn, when hot some little dieseling at the cut off
Oil pressure at 60/2000rpm decrease when thermostat open the way to Oil radiator
Water temperature (with auxiliary 12"electric fan ON) not exceed 212°F see my Digital Cooking instrument application
https://picasaweb.google.com/112770...&authkey=Gv1sRgCM70ivTIpL2oaw&feat=directlink
Electrical I have find one bad screw on a new fuse box
and have added one easy connect Digital voltmeter
Brakes some problem with the Hand brake regulation are on the way to be solved
Now the Speedometer mark a little more than 50 Miles
and due the hot temperature of the August in Italy one great BUG appear:
at the cold start all works normaly, after 5- 10 mile trip, 15 min from home, throttle linkages appear very hard to move, I have found that the TWO teflon bush on the command bar
are warm sensible,or dilatation of the bar is so great, that the system stop to work correctly
I am seriously oriented to jump the linkage system, with a
cable wire command- the others solution are or drive the caron winter only, or dismantle the interiors for change or modification of the two bushes .
I haven't see anyone that have the same problem on BCF
especially TEXAS and CALIFORNIAN drivers
Cheers
PS I have jumped the BATTERY SWITCH as programed
All is good -
are warm sensible,or dilatation of the bar is so great, that the system stop to work correctlyI am seriously oriented to jump the linkage system, with a
Cheers
Hi Guest!
